How much Alky flow thru the line when disconnected from the nozzle inlet when pushing the test button with Julio`s kit?
Mine will "spurt" out and then have a pretty light flow following it.
The car ran 11.7`s-11-8`s today, at 23 psi. Alky consumption was LESS then 1 inch of alky TOTAL as measured on the bottle, for 4 passes and three hard pulls going to the track. As well as a few spirited starts from lights! This would seem to be far less than 1.5 oz per second.
I have used less than 1/4 of the overflow tank provided for numerous testing, and todays runs.
Reason I ask is...
Went to the track today, and the 02#`s dropped each pass, with no other changes. I have never had any more than 1 degree of knock since installing this kit until today.
Started off at 800 0 KR thru the traps on the 1st pass. 777 1.4 KR, 2nd pass, 769 26.3
KR 3rd pass, and 757 15.7 KR on the 4th pass.
On the last pass I bumped the Alky during the run from 6 1/2 to 8 (max) with no 02 change at all. I am thinking a clogged filter, or maybe more pump adjustments may be needed. My settings in the controller are factory preset, and the #`s have been great on the street, and great the time before when I had the car at the track.
This car will sit untouched for 3-4 weeks without being driven. Maybe a pump issue from lack of use?
Thanks, Brian
Reason I ask is...
Thanks, Brian
