How much boost can I run with zxlene mix ?
turbotaone
I'm running 94 octane mixed with zxlene(70/30 mix).
I can run 20lbs.of boost with 0 knock. I was thinking about
turning the boost up some more and see what happens.
I would like to know how much boost you guys run on
zxlene ?
Thanks James
Just turn your wastegate rod in a turn and check your knock. If none, turn it up some more.
Yup..keep an eye on knock..thats about it..
With thrasher 92 and 93 octane I run 20psi no KR... I can get away with 21psi in 1st and 2nd though.HTH
Bo
