***How much ABUSE can these motors take?**** CORRECT TITLE
I have a stock 1986 Buick GN running on 91 octane throwing a Code 45 (so it smells like it's dumping straight fuel out of the exhaust), and running 16 lbs of boost. The car will almost always show (except for a couple times less than 1.0 degrees), at the end of 1st and in 2nd gear, 3-8 degrees of knock registering on the scanmaster. Of course I don't keep my foot in it after I see that but I've tested it enough to know that this is what is happening. Also, before I got the scanmaster and had it detuned somewhat who knows what knock I was getting. The most I remember seeing on my car was about 15 or so, before I detuned it and retarded the timeing a bit. Well actually one time from a dead stop only doing maybe 10 mph it showed 30! Car completely buckled. However, I replaced the rear main seal and timing chain not too long ago and took a look at the motor visually at least and checked my oil pan and there was only normal wear. Almost no metal shavings at all really in my pan. And this car is a 108,500 mile stock motor that was never opened before. I also rebuilt my oil pump and my oil pressure is now 25-30 psi at idle where it used to be 5-10. The car runs great and there are no problems and no smoking whatsoever minus that stupid Code 45 that I can't figure out. So my question is, am I just damn lucky this thing is still pulling like nothing happened? Have you guys ever detonated this much and still been okay before? I'm scared that maybe something could be weak in the motor but I don't want to open it up and find out everything is okay and waste money I don't have to. Tell me some of your experiences and thoughts please because I don't know if I want to push too much power through the motor now without a freshening up first. That means no quicker than mid to high 12's.
Oh, and the only thing I want to do but haven't done because I don't know how is a leakdown test to make sure the head gaskets check out. Also, I just found out both of my motor mounts are shot and the drivers side one, the rubber has disconnected from the metal.
