So, in summary;
A roller cam with supporting mods, can very well give 60 additional HP with supporting mods in a well designed “system”.
No talking about flat lobes, oils, injectors, turbo, chip, HW, pump, DP, IC, Alky, WB, scantool ……… Yadi yada.
Those things need to be in order and are not the purpose of this thread.
It takes a complete SYSTEM to get the significant HP benefits of a roller cam.
A roller cam just by itself has minimal HP benefits on a stock set-up, and may in fact (without supporting mods) have negative effects.
Supporting mods to take advantage of the roller are;
Heads (Typically rated around 40 hp)
With the better flowing heads, increased RPM and duration, you get 60. :wink:
(Valve Springs etc are just a requirement for installation)
IMHO, and NOT based on facts, you can expect:
+40 HP - Ported Heads
+30 HP - Increased RPM's
+10 HP - Cam Friction reduction
+5 HP - Increased valve lift
+5 HP - Increased valve duration
-10 HP - Increased spring rate
-20 HP - Increased friction with RPM
So there you have it - Net 60 HP :tongue:
