Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Thanks Bison.Similar grind to similar grind id bet ts not more than 10hp. Like a 212-212 FT vs. a 212-212 roller with 853 lifters. It takes a lot more spring to run a hydraulic roller than a FT on the similar grind. The roller lifters are heavy. If you were talking about the potential in an engine that could take advantage of a solid roller vs. a hydraulic cammed roller or FT in the same engine it could be a huge difference. Like 200 hp or more. ........
I am drawing that conclusion myself.
There is a LOT of HP in a roller, IF, the supporting mods are there.
Energy conversion is never 100%, so it can not be a "wash".I think it should be a wash.
Where does the energy go?
........ There's alot of other ways to add 60hp. Cam's not the cheapest way to add 60hp. .........
Scott,
I agree based on the postings of Nick and Bison.
If you start from scratch and have the $$$, get a roller.
If your motor already runs without mechanical problems, the $$$ is better spend elsewhere. Unless of course your goal is to be "top dog", or you get one HECK of a deal on a set-up.
