Boost it!
How much is to much is always different for every car... How big the, turbo, heads, cam, intake... blah balh... Every car is different. And each car will have its own "sweet spot". Even if your got 2 cars, botled thexact same parts on it, each would have its own "tune" to it.
I was running about 23-24 psi with my TA33. I too run a big cam like you Lee, 218/218, seriously ported 4.1 casting heads, and a Turbomotion V1 intake. But,as of tuesday of last week, the fabrication was finished to get the TA54 on the '85 and a set of MSD 50's went in yestrerday. So far I've got the car set at 19 psi in street trim, 93 octane, ZERO knock, with O2's in the 830's with fuel pressure at 42 static. So yes I've got more tuning to do, but there is more there for sure. In race trim I think this turbo can go 25-26 psi easy.
Two weeks ago I went to the track with the 33 still on the car (it hada bad oil seal on the compressor side mind you) and with only 20 psi, 26 degrees timing, 117 octane, 10 psi launch off the t-brake, the car went 12.148 @108.51 , 1.669 60', 7.647 @ 88.26 1/8th.
The car feels even stronger than ever before and once I get it a little more tuned I will be heading to the track to hopefully get kicked out for not having a cage
I will update ya'll as soon as I know anything more.
Best of luck to everyone!
Drew H. Carlton
'85 GN, 12.148@108.5, NO IC, NO SPRAY
