John Larkin
Sublime Master of Turbology
- May 25, 2001
I just put my parking brake cable back in and it seems to be working fine. However, I can engage it all the way to the floor and still make the car move forward in drive with less than 0 boost. Should I adjust the rear brakes tighter? As they are now I can barely turn them by hand (in neutral, both rear tires off ground, driveshaft still bolted in). I can also barely wiggle the drum off without loosening the shoes. Perhaps this explains my low pedal as well. System has been bled more times than I care to remember.
