GNONYX
- Oct 16, 2009
For many years of no support, the fuse panel underneath the steering wheel gave it that bow sagging ugly look.
I used a flat steel bar, drilled both ends for existing panel support screws , hole saw for interior light, and then riveted the flat bar to the panel.
I got the 1/8" flat steel bar from home depot, and I did checked out the aluminum flat bar, but it flexed more than steel. If you decided to do this keep in mind to file or grind down both rivet ends close to the existing panel support screws or it will hit the screw bracket.
