How to: Freshen your used 200-4r pump
INEEDAGN
Seen Your Member
PREFACE: THIS THREAD IS NOT INTENDED TO BE TAKEN AS "GOSPEL" AND I AM NOT SAYING OR IMPLYING IN ANY WAY THAT I'M THE FOREMOST EXPERT ON THE SUBJECT. THIS IS SIMPLY ONE PERSON'S WAY OF DOING THINGS AND I WELCOME ANY AND ALL FRIENDLY DISCUSSION IN THIS THREAD. None of this will be news to any of the veteran builders, but I'm doing this by request to help the average "guy in his garage" get his pump built as properly as can be done without machining the housings. I got good at these back when I worked full time at a trans shop doing 700r4 pumps. Thankfully for us, most parts interchange except the housings themselves, which greatly helps part availability and cost. Let's not forget that the 200-4r predated the 700r4 by three years, so the early build 200s are GM's first use of this style pump. which brings me to the first area of discussion.
What pump castings do you have and what's the difference? Early build pumps and pump covers are 149/150 casting number (ignore the red paint,it's the only early pump I have here), late castings are 082 body/088 cover and then the latest 690 body which used the same 088 cover. Here's the differences:
Early style is the bottom housing in this picture. The cavity that the orange screwdriver is stuck into is line pressure. Note how the early casting has the top land of the pressure regulator valve open for line pressure to exert force on it and uses a solid valve, and the late casting has the top of the valve area closed off. Now note how the late pr valve has a hole in it, EDIT: crap, you can't see the hole in this pic. Anyway, the late pr valve has a hole in it that goes from the area of the 90 degree pick, up through the valve and out the top of the valve into the now sealed off cavity. Still gets the same line pressure to the top of the valve, just through a different route. I can't dig up much info on this change but can assume that it was done to help isolate the land from pump pulsing in an effort to reduce PR valve buzz. I HAVE read mixed impressions about it's effectiveness. Some claim they won't use early pumps and some claim there's no practical difference. You do, however, need to know about this for interchange reasons. The "proper" way to do it is to use the 149/150 early combo as an assembly with the solid PR valve and use the late 082 or 690 body with the late 088 cover with the PR valve that has a hole through it. However, the only combo that absolutely won't work is to somehow end up with an early solid PR valve in a late housing. If you mix/match the parts it'll work as long as you have a pr valve with a hole in it. However, it'll work the same as an early design with line pressure acting directly on top of the valve and not through the hole.
This pic shows the early and late pump bodies with the tools pointed at the same holes as the cover in the previous pic. Note how the late casting was revised with a larger flat machined area to fully isolate the valve tip from line pressure and forcing it to go through the hole in the revised valve. If you use an early body with the late cover it will allow line pressure to go around the newly sealed off cavity and negate any gains from the design change. It WILL "work", however.
Quick pic of the pr valve circuit from the manual. My manual only shows the early design, not sure if a later revision bothers to show the late design??
Again, if anyone has more detailed info or testimonial from using early vs late I'm all ears.
EDIT: Full size pics were getting out of hand to scroll through so I edited all the posts to insert the pics as thumbnails. Please click on the picture if you'd like a larger image!
Teardown: Remove the 5 bolts that hold the two halves together, set the stator side of the pump aside and start on the pump body. Remove the top ring, the rotor and vanes, and rotor guide. Pry the spring(s) out from the slide with a rag over them to keep them from flying off. For some reason I forgot to take pics of all of this :red face: but i assume you have a manual of some sort if this is the first time you've been in one of these anyway. Remove the slide, pivot pin and pay special attention not to lose the little spring under the pivot pin.
Now take a screwdriver and hammer and pry out the old seal: (I'm using the red pump only because I've already removed the bushing and seal from the one I'll be building).
Using a bushing driver, remove the bushing. If you have a 690 pump body, you will have to remove it by driving it "inward" because the 690 pump body has a ridge in it to prevent the bushing from walking out. You can remove this with a screwdriver or chisel (carefully) but you'll want the proper driver to reinstall it anyway. Mine's custom made just for this bushing, I haven't looked but I'm sure they are commercially available.
Next two pics will show the difference in seal area. 149 and 082 are identical here. 690 has the aforementioned step as well as a bit more relief for seal drainback.
Now. Bruce from PTS was an avid believer that the earlier bodies needed to be milled out here a bit to match the 690s profile for a drainback aide. I doubt it makes any difference in reality but just for fun I'll include a pic of one of my adventures doing the same thing in redneck fashion:
I don't recommend that "mod" I just inserted it for comic relief. Though I did put that in a trans....
Inspect the pump vanes where they contact the rings. If theres a visible notch in them, replace them (same as 700 and cheap). You can reuse them if they're not worn. Pic of an acceptable one vs a worn one (and they can be much worse than this):
Now, take the original pump rings, clamp them in a vise and snap them in half:
This is done to A: illustrate how brittle they are and B: keep you from ever reusing them. We will be replacing them later. (note: if its been apart it may have better rings in it already and they may be harder to snap or impossible. Replace them anyway so you know what you have. More on that later)
Plastic rotor guide: Gently try to flex it. If it's not brittle it can be reused, but honestly, they're like $1. Be sure you're getting a 7 vane guide when you purchase.
Obviously inspect the rotor and slide for any cracks or obvious wear, on the rotor make sure you inspect the tabs where the converter engages it. Now back to the pump cover (stator side).
Take a snap ring pliers and remove the PR valvetrain, starting with the boost valves. They are spring loaded, so a couple gentle pushes on it usually gets them to pop out. If they are stuck you can gently (and carefully) pry on the pr valve to help force them out. Just don't damage any valve lands or the machined surface of the housing. I'm including pics of the lands you measure to determine the size of the boost valves. This pump is out of a BRF core so it has factory .471/.265 valves. Note the hole in the PR valve as mentioned earlier.
Now, in the pic above, the orange screwdriver is pointing to a land on the PR valve. Sometimes this land gets modified with a flat spot ground into it or ground completely flush with the stem of the valve. Flat spot is ok (allows adequate converter and trans cooler/lube flow regardless of PR valve position), ground flush runs the risk of excessive converter charge pressure which can stress the thrust surface of your crankshaft (or at least that's what the internet says). I'm honestly not an expert on that mod, I leave the valve alone. I've been told that even a flat can affect line pressure by 30 psi but I've never tried it. A before and after test in a car is on my "someday when i'm bored" list which means it probably won't happen. In rare cases the top land of the valve may have a flat ground on it. It's a transgo "fix" for the wrong pr valve/pump casting mismatch. If the top land has been touched, replace the valve with an unmodified one. I believe the 700 stuff is all identical and I also believe the reamer and oversized pr valve from the 700/early 4l60e can be used if the bore is worn. Someone correct me if i'm wrong.
Remove the lockup valvetrain as shown. Then remove the pump relief spring pin, spring, and ball. It's a stiff spring so it's a good idea to cover it with a rag when you remove the pin. If there's a filter o-ring still in the housing, carefully pry it out without scratching the bore. If the bore is gouged from a previous filter change, now is a good time to smooth it out with fine sandpaper.
IMG_5743.JPG IMG_5744.JPG IMG_5745.JPG IMG_5747.JPG IMG_5748.JPG IMG_5742.JPG
Remove the T27 screws holding the stator tube to the housing. If they become stripped you can grind a slot for a large flat tip screwdriver or grind it off completely and remove it after the tube is pressed out. PRESS the tube out using a hydraulic press (not a hammer), placing the supports as close to the center of the housing as you can while still allowing the tube to press out. Middle pic is a comparison of the original tube (note the wear on the splines) and a hardened tube. Hardened tube is cheap and should be done in every build, every time regardless of the condition of the original splines. If the pump has been apart before, it may have a hardened tube in it already. You can leave it in if the machined face of the aluminum housing doesn't need any work to it.
So at this point, you should have two bare housings. Start by enlarging the 3 drainback holes in the pictures below. This relieves pressure on the seal and prevents the seal from leaking or blowing out of the pump body. *Some builders believe that this modification is useless and only risks ruining the housing if you screw it up. I will completely agree that it will make no difference in how the pump performs on the day you build it. However, I do believe that when the pump gets some miles on it and the bushing/rotor/housing start to wear and combined with our new max pressure of 250+ psi, that it makes a great difference in alleviating the additional oil that makes it past the bushing. The fact that everyone locktites the seal and uses a seal retainer ought to be proof enough that it's a problem, but I became a real believer when I freshened a trans from one of the vendors that was pulled because it was leaking from the pump seal only under hard acceleration. When I got it apart, the pump drainback holes were stock. You could make an argument that the pump was worn and the trans was on borrowed time regardless, but the point of all these little mods is to keep the unit out as long as possible. In that particular case, this was the first point of failure. Besides, IT'S FREE!
The two holes in the body are obvious, but don't forget the mating hole in the cover.
Don't be a hero, enlarge them one or two drill sizes at a time and it'll go a lot smoother. Go to at least 1/4", 9/32" to 5/16" is better. Chuck the drill bit out toward the edge of the chuck to make it longer and easier. Use the intersecting hole as a visual guide that you've drilled it far enough.
Using a countersink or a deburring tool, make sure the holes are deburred well. This is especially important on the two surfaces that mate together with no gasket. If they aren't perfectly flat, you'll cause the whole pump to crossleak.
Now we deal with the machined surfaces of the housings. There's no gasket here, so if these surfaces aren't perfectly flat, you'll have cross leaks. Next few pics are of areas where the housings aren't flat due to GM staking the cup plugs in, If you check these against the opposing housing you'll notice they fall into a cavity and not the flat machined areas. One is pretty close but I don't believe they will cause any problems if you have to leave them alone. Third pic is of random damage caused by the housings being mishandled after machining when they were new. If you can't flat sand the housings, you need to at least inspect them closely for this kind of stuff (on all surfaces) and use a whetstone to true it up if necessary.
Now, I happen to have a pair of granite surface plates with sandpaper on them for flat sanding. I realize most people who would actually use this tutorial don't have access to this and must use a whetstone on a nice housing to get by with. You should look into a cheap 9x12x2 granite surface plate though, they're pretty cheap and even the cheapest ones out there are flatter than they need to be for sandpaper. 9x12 accepts any old store bought sandpaper grit and comes in handy for flat sanding everything engine/trans related. I have a 120 grit and a 280 grit in 18x24. I can elaborate on the stones more if anyone would like me to. On the pump housing side, I just hit it quick and look for the sanding marks to be even all the way across, indicating it's flat. Occasionally I'll see raised areas around the bolt holes that need a little sanding to flatten out. I don't know if this is caused by overtorquing or overheating or ??? but it's something to keep an eye out for. I hit this at the bare minimum because I don't want to change the dimension of the pocket depth, I'm just verifying flatness.
The next two pics show the wear on the cover side housing that I'm going to sand out. As long as I turn the housing often as I sand it, I can sand out a lot of wear here with no concern for dimension change as it will stay parallel to the back side surface. First pic is a straight edge with a flashlight behind it showing the groove from the rotor. Second pic shows the wear from the slide as well as the rotor and vane marks. This pump was out of a pretty damn decent trans, yours will likely look the same or worse.
I ran it on the fine paper just once or twice to highlight any high spots for pictures. This shows the staked plugs and how much aluminum is raised by them. Third picture is interesting. Remember the drainback holes I enlarged and deburred? Yeah, that still wasn't flat. If you can't flat sand your housings, be DAMN SURE those two mating areas are flat. Whetstone or equivalent method. The drill bit raises more aluminum than you can see with the naked eye.
Sanding my arms off...and a midway progress pic...
ALL DONE! If you look closely you can see I didn't get the deepest groove completely out, but the slide marks are gone and the groove won't catch a fingernail anymore.
Now it's time to notch the housing so I can stake the bushing in it. Using a round file, cut two angled grooves opposing each other. You can do it without cutting into the rotor guide area, I let this one dig in a little on purpose to illustrate that it makes no difference if you do as long as its deburred. Note the notches don't go all the way down the bore, we don't want to take away any more surface contact area than we have to. *Some builders won't bother to notch a 690 pump body due to the step in the front being able to hold the bushing. I stake every bushing out of habit, from the old 700 days. Here's a fine time to mention that I've seen a couple of the 082 pump bodies that had the step in them just like the 690, although it wasn't as pronounced. One of them is now in "usetaboost's" car.
I'm not installing the bushing yet, but I notched it now because I wanted it done before I "hand lap" the pump cavity. 400 grit sandpaper from a roll is perfect for this, it will break the glaze and remove minor marks without changing the dimension easily. 600 would work and might be better for a novice, I would think it to be damn near impossible to change the dimension with 600 grit. I use a few drops of trans fluid or penetrating oil so the paper doesn't clog up, and then use my thumb in a repetitive circular motion while turning the housing (yes, I'm left handed). First trip around the housing, I scoot my thumb up the roll often, keeping fresh paper under it. Second trip around, I leave the "dead" paper under my thumb for a smoother finish. This was something I got good at in the 700 days and is second nature to me now. Just try to get all the way to the outside of the cavity and sand it as evenly as you can.
You can't see it well in the above pic, but when rotating the housing in the light I can still see traces of the original rotor marks. This tells me I didn't change the pocket depth. This is done for the same reason you break any glaze in an engine or trans and the reason you crosshatch a cylinder: Oil retention. Most used pumps will still show a groove or two after sanding this pocket. As long as they aren't severe they won't hurt anything or cost you any max pressure.
Now I surface the rotor and slide. I start with the slide ring, leaving it in the slide with the old o ring under it. On this pump I did a quick rub on the fine grit stone because my 280 is about dead. If it was a new sheet I might hit it on the 9x12 stone with some dead 320 or finer after the 280. I really doubt it matters much, again, this is just how "I" do things.
Now I remove the ring and surface both sides of the slide and rotor....note the marks on the top side of the slide aren't completely gone. They won't hurt anything. I might be able to sand them out but it would likely alter the slide clearance in the cavity by the time they were gone. Also should note: DO NOT try to sand the inner surface of the slide where the pump vanes rotate. The slide is treated with a process called Parkerizing, which is an anti-wear coating and even if it has some wear showing, you'll do more harm than good by sanding on it. If most of this coating is gone you should consider slide replacement.
Now I'll give the parts a quick spray and check clearance with plastigauge. A strip of plastigauge is literally $2 at the local parts store, go get a strip and use it. I use three small strips of plastigauge on both the slide (without seal) and rotor, then torque the cover on at 18 ft lbs. This one ended up right at .002. Perfect. Steve V and Richard Clark have an alternate method of checking clearance and Steve can chime in with it if he wants to share it.
I checked it with a straight edge and a feeler gauge which loosely verified the plastigauge. 1.5 thou barely fits under it in most spots and a .002 doesn't quite fit, but if I lift the straight edge to place it under it, it doesn't have any wobble to it when set on the .002 Ideal pump clearance is between .001 and .002. For your average garage build, the slide can be quite a bit looser than that (.003 or more) because it has a positive seal under it. I've let the rotor be .0025 or so before and never had any issues with pressure loss. I've always wanted to assemble a "loosey-goosey" pump and see how it affected pressure but never have, mostly since I have the ability to get it right. Maybe others will chime in with more data on pump clearance vs. consequences. I do know if the slide is too tight it will bind in the housing, the rotor would probably "self clearance" if it doesn't break first.
Now that we have the parts all surfaced and clearance checked, we can start the assembly. Spray both housings thoroughly with brake clean and blow dry with compressed air. Let's start with the pump cover/stator support.
Grab the old stator support and chuck it in a vise. Use an .045 drill to enlarge the orifice in this cup plug inside the alignment pin. This increases lube oil to the "mickey mouse" washer behind the pump. In the event you can't enlarge this, at least verify that it's not obstructed and that it was punched cleanly from the factory. Note about this cup plug: Not all of them are staked into the pin from the factory. I have seen one fall out (was wedged sideways in the washer upon disassembly). The pin is hardened and does not deform easily, so it is difficult to stake/peen the opening to prevent this. I can tell you from experience that it will break the tip off a snap-on chisel without deforming the pin. I don't know how rare that failure is, but if you choose to find a way to peen the end of the pin you'll have to get creative, and you'll want to do it before the pin is reassembled into the housing. The top pic is not factory staked, middle pic is. Bottom pic is showing me removing the pin from the old stator support with a punch.
Tap the pin into the new stator tube, use something with a 90 degree angle to "eyeball" that the pin is straight in the flange and parallel with the tube. PRESS the tube into the housing (Again, no hammer) making sure the support plates under the housing are positioned as close to the center as you can while still allowing the tube to pass between them. A couple grease rags are a good idea to protect your freshly sanded face from damage, especially if the support bars have been through hell. If you're a novice and this task gives you fits/makes you nervous, you can place the stator tube in the freezer for a while and set the housing somewhere warm like on top of a heated parts washer and it will slide in easier. Just keep an eye on the pin orientation on the way in. Clean the bolts and threads in the housing with brake clean and blow dry. Apply a single drop of red locktite to the bolt threads, torque the bolts to 10 ft. lbs. If the original bolts are damaged or if you have difficulty with the torx head, you can replace them with an ordinary M6x1.0 thread hex head bolt, just check the fit of the mickey mouse washer.
The stator tube flange is pretty soft metal and can easily be staked with a punch to hold the pin from walking out against the washer. Pin can't really go anywhere except against the mickey mouse washer once its assembled, I stake it anyway. >BEATING THE HELL OUT OF THE PIN ONCE IT'S ASSEMBLED COULD BREAK THE HOUSING BY FORCING IT THROUGH THE BOTTOM OF THE ALUMINUM BORE. IF YOU DOUBT YOUR ABILITY, DON'T STAKE EITHER THE PIN OR THE CUP PLUG INSIDE THE PIN. IN FACT, FORGET I EVEN MENTIONED IT (LOL). <
insert forgotten pic here
One problem that happens with high pressure pumps, is that when we make enough pressure for the pressure release valve (blowoff valve) to open, it can cause the spring to start breaking 1/2 coils off where it rests against the narrow pin. This reduces spring pressure and makes the ball open early, causing low max pressure and/or pump buzzing. To solve this, insert a hardened washer between the pin and the spring. An easy source for a washer is to get an extra lockup valvetrain washer from another pump or your local trans shop (same as 700), it measures .040 thick. I use a stainless steel washer that measures .060, I only do this because I have a whole stack of this washer here with no other use for them. I wouldn't trust a mild steel washer here (use the lockup washer). I'd like to publicly thank Dave Husek for this tip after I had this issue with the very first 200-4r I ever built with performance in mind. Couple of the vendors carry a better spring that also raises the blowoff pressure from ~260-270 to over 300 psi.
Clean, lube, and insert the lockup valvetrain as it was removed, making sure the snap ring is properly seated and that you can move the valve by pushing it with a small screwdriver through the hole. If you are building a non-lockup trans, replace this valve train with a non lock up kit and use their instructions. One area I have no experience with is with the very early/diesel/export transmissions that have a hydraulic lockup valve in the valve body. I don't have any of that here so I don't know if any of this valvetrain is different. If someone else has this info please post it here.
Here's the part where I would normally install the Pressure regulator valvetrain and boost valves, but apparently I forgot to order the damn things. For anything that resembles a performance build, use an aftermarket PR spring, either the one that comes with your shift kit, or order the purple TCI spring from summit or jegs, OR if you're going super low budget and don't have the $11 plus shipping, walk into any trans shop and ask for a transgo green PR spring. They probably have a pile of them laying around (again, same as 700r4). ANY performance oriented spring will be better than stock, I believe the purple TCI will give the highest base pressure but I'll confess I haven't done any back to back testing.
On the subject of shift kits, I highly recommend a kit from a known 200 guru. I strongly DON"T recommend the base transgo kit for ordinary passenger car use, especially the "bootstrap" tv plunger/valve setup. It's the exact opposite of performance and even transgo knows that, because they don't use that in their HD2 performance kits. Sorry for the derailment from pump tech.
Boost valves: .500 main boost valve is cheap, effective, and available everywhere. Larger ones exist but the .500 will be ideal for anything built by anyone actually following this thread (garage hobbyist). Reverse boost valve: if you've got the largest factory one (one pictured above) it's fine for any garage build. Larger valve here only gives you additional pressure boost in manual 1 and manual 2. Some aftermarket boost valves have O-rings on the outside for better sealing in the bore, it's builder preference though. The non o-ring factory style works fine. Most of the valves are kind of hangy when new and I end up polishing the valve. You can also polish the PR valve and lockup valve if they're scored up, just use fine sandpaper (400-600ish).
Pump bushing: Number 1 in the picture is the OE style babbit bushing. Number 2 is the teflon bushing that trans shops used for the better part of 15 years, and solved a lot of problems with, until one day (circa 2012) they quit making them. I've heard a couple versions of the story but my personal favorite was "they were shipping production of that bushing overseas and the boat carrying all the tooling sank". Not sure why i'm keeping this one, I guess I kept it just for this picture? Numbers 3,4, and 5 are the teflon bushings available today. Notice 2,3, and 4 are a split bushing with a simple butted seam and number 5 is a solid bushing. Number 3 is a sonnax bushing and I think number 4 was from transtar. The bushing saga unfolded after I quit the trans shop and I can't honestly speak for which one of those two would be "better" if any difference at all. I've used whichever one i'm holding at the time as long as it's a split bushing. I've tried pressing the solid bushing (number 5) in on a couple different occasions, and both times they were tight on the converter hub and I didn't use them, but they do fit the direct drum quite nicely. Number 6 is a "sure seal" bushing by teckpak/fitzall, note it has a rubber o ring in the middle. This is an attempt to keep oil from pushing the front seal out. I've never ran one, as my former boss/mentor told me to run far, far away from them. I'd rather do the proper drainback/seal mods. I wouldn't be surprised if there's a bushing or two I've missed or if there's a cheap knockoff of the split teflons out there somewhere. Anything that's the same as a 700/4l60e and needs replaced in every build is bound to have a wide variety of options.
Numbers 2 through 4 are actually a porous bronze bushing with a teflon layer on top/in the pores of the bronze middle layer. I haven't ever tore into number 5 to see what it is, feels like a thin teflon layer on a babbit bushing, maybe i'll mess around with one this week and update this post.
Again, any veteran builder with feedback on current bushing selection can feel free to correct or elaborate on anything I've posted. When I was doing 700 pumps, it was bushing number 2, ordered by the dozens and they just worked. I'm now out of the loop I guess.
So before pressing in the bushing, make sure the housing is final cleaned for assembly. Take some scotchbrite and clean the residue out of the seal bore, and check it and bushing bore both for any stray screwdriver/chisel gouges and correct as necessary before brake cleaning the hell out of the housing and compressed air drying it. I'm anal about surfaces being truly clean for things such as loctite so I take a paper towel and some denatured alcohol and wipe the bushing/seal bores clean as well as the outer surface of the bushing itself.
Now, to be "correct" here, you are supposed to use green sleeve retaining loctite for something like holding a bushing in the bore. However, red high strength is what everyone has laying around and I've honestly never heard of anyone using anything else, even if it's not "correct" and it works just fine in conjunction with staking the bushing inside literally thousands of daily drivers every day. A light, even coat spread around with your finger is best here, putting too much on only makes more to wipe off after it's pressed in/staked. An arbor press is your ideal tool, but it can be done by hammer and driver and I assume that's what you're going to have to do in your garage. You can use a wide flat driver to get it started and then use the correct driver or equivalent to get it seated the rest of the way. Oh, and make sure the split of the bushing is indexed approx. halfway between your notches you filed.
690 pump body, press it up to the factory lip but don't hammer on it once it touches, as it can absolutely be forced past it. check fit on the torque converter, or if for some crazy reason you don't have a converter neck, use the small end of the center support (same dimension as converter neck which is why you can use the teflon pump bushing in the direct drum). On the earlier pump bodies you want to center the bushing in the bushing bore.
We now stake the bushing. Use a small roll pin punch, holding it exactly like i've pictured will make your life easier. Use your leg and/or beer gut to hold the body against the bench. I'm (still) left handed so you may need to mirror this image. My index finger is keeping the punch from contacting/nicking the freshly sanded housing, my ring finger is right against the tip of the punch, preventing it from slipping down the bushing. My thumb is keeping it from slipping into the pump cavity. Try it that way and thank me later. Note that on this pump, the bushing is slightly recessed in its bore and there's a distinct lip there. The 690 pump body has a deeper bushing bore than the early cast. Earlier castings, your bushing should be perfectly centered in the bore (as I've already stated once).
Take a razor knife or pocket knife and clean up any burrs or teflon dingleberries, and then wipe up your excess loctite before it dries. (I've already installed the front seal in these pics because my bench isn't close to the arbor press and I wanted to save steps.) Had a couple more angles of this process pictured but hit the 10 pic limit for this post.
For the front seal, back in the day we used to go through an arduous process of taking the seal to the wire wheel and cleaning off all the original "boretite" coating, then taking scotchbrite/brake clean to clean off the remaining residue, then wiping it clean and applying a healthy coat of red loctite to the bare steel and then using the seal retainer after the seal is in. I don't do that anymore and i'll show you why here in a minute. I DO still put a thin coat of loctite on it out of habit but it's probably not necessary either.
SO, press/drive the seal in using the proper wide, flat driver....
...or if that's not available, the original stator tube fits it like a glove...
Now, index a 700 seal retainer until you find a spot where all 4 tabs go on and miss all the ribs. Then tap it on with a hammer. NOW, take your bare fingers and pry that damn thing right back off, crack a beer and stare at that design for awhile, realize that it can barely hold itself on, let alone hold the seal from blowing out. When your beer is gone, get out your mini file set and fix the design.
Using the 4 witness marks as your guide, file 4 notches in the housing to give the retainer something to grab on to. This will take some finesse, your choice of file and the angle you hold it at makes or breaks this project. You want to back cut it in a way that leaves the metal finger a 90 degree edge to grab/lock on to. Test fit the retainer and file the notches higher up the casting, until all 4 fingers lock on good.
Not going anywhere now!
Pump assembly:
Obviously, clean all parts thoroughly before assembly. Insert the rubber o ring into the slide with some assembly gel (or petroleum jelly), then use the gel to "glue" the slide ring in the cavity with it, keeping track to put the surfaced side out towards the housing.
Now's a fine time to lube the bushing and spread some lube around the cavity a bit, then set the slide in the cavity (steel ring side goes down).
Don't forget to install the small spring into the cavity under the pivot pin
Install the slide seals as shown. The square seal is the actual seal, the round part holds it tight against the pump cavity wall. Depending on the brand of your kit, your new seals may protrude out of the cavity and if so, will need to be trimmed off with a razor blade.
Insert the slide pivot pin, making sure the seals on the opposite side stay in their proper place.
You will need to purchase a transgo 700-pkh hardened ring/spring kit. They're cheap. You need the slide spring out of this kit at this time.
Instructions say to crunch it in a vise once before install and the spring will take a set. Who am I to argue?
If your pump came with one, or if you can procure one, use the stock inner spring with the transgo outer. This is more important with higher rpm engines. If you want to deviate from this setup, Steve V graciously did some recent testing of different spring/spacer stackups and posted his findings. Do a search or maybe he will post it later in this thread. It's not my information to copy into this thread. The short version: Higher RPM needs higher spring pressure to counteract inertia/centrifugal force. Do some searching if you want to go full nerd about it.
Some prefer to put both springs into a bench vise and compress them and then carefully slide them into place. I use a screwdriver and a cuss word or two. If you place them down against the housing and force them in on the slide side, you won't burr up the nicely decked housing you created earlier.
Stick the rotor guide to the rotor with some transjel or vaseline. Then stick one of the transgo pump rings to that. Then flip the rotor over and install into the housing.
When you install the pump vanes, pay attention to the direction, and if they are used vanes, install them so the side that originally contacted the rings continues to do so. (side with two shiny flats goes inward). May have to rotate the rotor as you do this to get the lower ring moved into a favorable angle to allow them all to fit. Then you install the top ring. Then lube the assembly.
Place the stator side of the pump onto the body side. Rotate it so all 5 bolt holes line up (only lines up one way) Pick up the body and finger tighten all 5 bolts. The two halves must be perfectly aligned before torquing. You can buy the factory tool, or you can use a $4 large hose clamp as an alignment band. You can also use several smaller hose clamps linked together. Some even drop the pump upside down into the empty trans case for alignment.
While you're doing it, you might as well line up that drainback hole you took the time to enlarge. Second photo shows the correct position of the alignment band around both halves. Torque the 5 bolts to 18-20 ft-lbs. and remove the alignment clamp.
Install the new o-ring around the outside, making sure it's not twisted and the painted side is out. When installing into the trans, don't forget to stick the mickey mouse washer to the back of it and don't forget the small pump screen filter. And that, as Smokey Yunick would say, is a race ready part!
Scraped the Teflon layer off two of the Teflon bushings to show the difference.
This is the same bushing as number 2 in the post above. This is a used bushing I took out. Note the porous bronze middle layer (again this is a split bushing).
This is the same as number 5 above, note a very thin Teflon coating over Babbitt. Gouged into it good just for fun. (Again this one was a solid bushing).
Shout out to the veteran builders, has anyone been using these Teflon/Babbitt solid bushings in either the pump or the direct drum and are they holding up? I was sent two of them in a kit from a vendor but I won't name them because I bought their kit right after the originals became unavailable and it was probably the only thing out there at the time. I've been using them in the direct drum but not the pump. I still have a few to use up.
