how to lock the converter with a switch?
blackstallion
which connector ports on the aldl do you ground to lock the converter i would like to use a switch,and how would u now its locked.How much is it worth at the track which is the only time i would use it.I ran a 13.2 at 106 on street tires could this get me in the high 12's maybe 2.3 60ft.
As I recall, the A and F pins need to be jumped. If all is stock,
this shouldn't be too big of a load on the car for a ¼ mile run.
As you begin making more power, you will be putting more
stress on the T/C, and might not be healthy in the long term.
Gains of .1 to .2 sec, and, a couple MPH are supposed to be
what most people see. I was able to get my Firestone Firehawks
to a 1.94 60' in stock trim. Best run before I started to lean on
the car was 12.94 with the Firehawks. I am in Vegas at 2500',
your time should be better or worse depending on if you are
higher or lower. 13.2 @ 106 is pretty respectable in stock
trim.
