t-topflyer
- Aug 8, 2007
I did a search here and on some other forums and found the powermaster bleeding procedure thread here, which is great very detailed and should be a sticky:
http://www.turbobuick.com/forums/br...ls/218912-powermaster-bleeding-procedure.html
However, and this may be a stupid question; I apologize if it is, but I don't really want to bleed the system (unless necessary) I just want to maintain a normally functioning system.
With that in mind, how do you properly maintain a normally functioning powermaster brake system?
Do you need to switch out all the fluid and if so how often? Annually?? every 2, 3, 4 or ? years
What's the easiest and most efficient way to do so?
Is there a certain type of brake fluid that is recommended or one that should absolutely not be used? What about a DOT 5 Silicone Fluid??
Is there a write-up on this site or another that goes into a step by step procedure on how to do this, or is the bleeding procedure thread what should be done each time?
