Rafs-T-Type
Not so Senior Member
- Mar 8, 2009
I broke the first two trying to get them in.  Whats methods do you guys use?
tap lightly:smile:
 then the 3rd snapped
 then the 3rd snapped  .  I then had to take the shaft back out so I could get what was left of the button out of the shaft as well as any broken button residue, as I did with the first 4 I already busted.  Also it hit me that it would be insanely hard to maneuver for the last couple button's installation.  Then came the good times
.  I then had to take the shaft back out so I could get what was left of the button out of the shaft as well as any broken button residue, as I did with the first 4 I already busted.  Also it hit me that it would be insanely hard to maneuver for the last couple button's installation.  Then came the good times  .  Screwed the damn shaft down to the work bench(carefully setting the drill gun as to not over torque the shaft and bend/damage it), with the holes aligned perpendicular to the table.  Then got the mini sledge out and they went in beautifully....So I thought.  I had one of the caps bust on the first start up, but I am well on the way now.  Just gotta wait til tomorrow when I get more buttons since I have a total of 7 broken ones now....make that 6 broken and one lost.  Screwing thing to the table is the way to go though!
.  Screwed the damn shaft down to the work bench(carefully setting the drill gun as to not over torque the shaft and bend/damage it), with the holes aligned perpendicular to the table.  Then got the mini sledge out and they went in beautifully....So I thought.  I had one of the caps bust on the first start up, but I am well on the way now.  Just gotta wait til tomorrow when I get more buttons since I have a total of 7 broken ones now....make that 6 broken and one lost.  Screwing thing to the table is the way to go though!I kept breaking those buttons too when I did my rebuild last year. So this is what I did instead. 5/16-18x1/2 low head cap screw and some nylon tube stock (5/8 OD - 1/4 ID). Tapped the shaft holes (I have the thick wall shafts), bored out the ID of the nylon tube stock, cut wafers to the ~size of the stock buttons, and assembled with thread locker. No problems to date.
 One thing I didn't quite get is why you had to bore out the ID of the nylon.  Seems like you would use the 5/16" screw with the 1/4" hole and have a nice fit.  Of course I guess that could cause some shavings that may work their way out latter.
  One thing I didn't quite get is why you had to bore out the ID of the nylon.  Seems like you would use the 5/16" screw with the 1/4" hole and have a nice fit.  Of course I guess that could cause some shavings that may work their way out latter.I kept breaking those buttons too when I did my rebuild last year. So this is what I did instead. 5/16-18x1/2 low head cap screw and some nylon tube stock (5/8 OD - 1/4 ID). Tapped the shaft holes (I have the thick wall shafts), bored out the ID of the nylon tube stock, cut wafers to the ~size of the stock buttons, and assembled with thread locker. No problems to date.
put the info in the fabrication section. This is a great idea and should be there for everyone.:biggrin:
Put the info in the fabrication section. This is a great idea and should be there for everyone.:biggrin:
sd-slider said:
I dropped the buttons in hot water for a while. They pop in easier and won't break when heated. Some use a torch, but you can melt them.
