Rafs-T-Type
Not so Senior Member
- Mar 8, 2009
I broke the first two trying to get them in. Whats methods do you guys use?
SignUp Now!tap lightly:smile:
I kept breaking those buttons too when I did my rebuild last year. So this is what I did instead. 5/16-18x1/2 low head cap screw and some nylon tube stock (5/8 OD - 1/4 ID). Tapped the shaft holes (I have the thick wall shafts), bored out the ID of the nylon tube stock, cut wafers to the ~size of the stock buttons, and assembled with thread locker. No problems to date.
put the info in the fabrication section. This is a great idea and should be there for everyone.:biggrin:![]()
Put the info in the fabrication section. This is a great idea and should be there for everyone.:biggrin:![]()
sd-slider said:
I dropped the buttons in hot water for a while. They pop in easier and won't break when heated. Some use a torch, but you can melt them.
