My comp 212/212 roller non billet cam was eating into my block. The way Richard Clark showed me how to repair it was to machine the block on a mill, then install a bronze washer cut out of bronze shim stock.
This is the before pic, notice the thrust surface near the oil galley plugs.
This is the washer. It's .040 thick. Not pictured we drilled a hole for oiling.
Here's the brass shim stock
This is what my cam looks like.
Setting the block up on the mill
Here we are indexing the bit to a surface on the block that's not chewed up. We checked both side and the top of the block. Sides where the same, top was .002 thicker.
First pass.
Half way there. Took off .021
All done. Took off .0415 total. Adjacent cam lobe interference was checked before and after. No issue there. Big thanks to RC as usual .
First pass.
