SignUp Now!Hey Bob, in the instructions and on almost every other post I can find, you say to turn cfg 2 ON for the remote rpm switch. I have been trying to get this to work and finally found this thread where you said cfg4. Tried it and it worked. Question, is cfg 2 need to be on or off? And what does it do?the potentiometer has 3 terminals, use the center and one of the outer terms. connect gray wire to one terminal of the potentiometer, the other terminal gets connected to ground (engine ground is best)
the orange trigger wire is connected "normally": 12v----- switch ----- orange wire
To enable this, set the trig limiter setting to 0 (all switches off) and turn Cfg4 on.
Set up this way, the potentiometer setting will control the 2-step RPM.
In version 1.4 and later the tach will read the 2-step RPM any time the 2-step is triggered and the engine is not running. this way you can see what it is set to.
Bob
