HUGE LIST converted to V8
brisbon
email me serious offers with reasonable shipping included to mattbrisbon@gmail.com I have paypal and take credit cards over the phones at my shop in massachusetts.
If the offer is reasonable and youve supplied your phone # and shipping address Iwill call you and arrainge payment and ship it out.
price item
if
new
55 waterpump to intake manifold "s" hose used
40 lower radiator hose used
50 belt used
6 oil cooler o-ring new
50 power steering pulley used
200 power steering pump new
65 power steering lines new
150 starter new
45 billet vac block at plenum for vaccum brakes
45 billet vacc block for stock vaccumm setup
50 coolant piped at intake to heater core, used
170 MAF used
100 MAF pipe powder coated w/hoses
50 oil cooler hoses, stock style new
20 evap canister, used with new filter and solenoid
34 used water pump
?? cruise control assembly at fender
65 crank sensor w/bracket, used
124ea ignition control moduals, two available, used
350ea coil packs, used two available
?? coil pack/ign modual mount bracket
?? stock harmonic balancer and pulley
130 fuel pressure regulator, billet, accufab
50 fuel injector rail, used
20ea stock motor mounts, new
?? vaccumm hard line set, used
300 intake manifold, ported to gaskets, silver powder coated
40 thermostat billet nipple w 6 deg thermostat, used
35 EGR blockoff plate
?? accessory steel mount tube shaped brackets powdercoated
200 tensioner, belt - used
200 distributor assembly for cam cap style, used
70 cam sensor, caspers with led timing
189 Valve covers TA black wrinkle finish aluminum used like new
64 TPS like new
75 IAC like new
90 IAC billet angle boss
35 Air Temp Sensor used
295 throttle body 70mm polished, used
200 upper plenum/doghouse 70mm polished used
65 RJC power plate for rear cylinder lean protection
500 razors ALKY kit complete, used ONCE
1800 FAST XFI with buick adapter complete, used ONCE
900 cottons FMIC used ONCE
279 downpipe 3" cottons performance for external wastegate, used
500 rg-45 external wastegate used
65 braided teflon swivel turbo oil drain
1300 Turbo 66 series BBturbonetics f1 wheel w/g port bored,used
600 Header set with crossover Postons ceramic
500 exhaust cat back 3" SS used (pickup only)
200 Cutout for testpipe electric used
80 test pipe used
100 stock electric fan, used
330 injectors 60lb mototron
100 injector harness caspers upgrade kit
220 front cover aftermarket with oil pump and oil filter housing
56 arp main stud kit, NEW
100 ECM stock used with 94 TT chip (85$)
200 b and m engine oil cooler with electric fan and thermostat along with braided SS teflon hoses and oil cooler filter adapter
150 turbo saver billet oil system, used with extra filters
200 Fuel lines at front cover SS, used
25 gage pod, a piller new
150 gage pod a piller with digital boost and a/f gage used no senders
65 dipstick tube and stick, used painted
175 A/C hoses and lines, used with crimped on r134a adapter manifold
300 Alternator 200amp powerbasterds, used one week
200 rebuilt stock alternator, used
250 ScanMaster complete, used
174 ESM modual, used
200 a/c compressor used
unpriced
set main caps with two extras stock used
set of stock rods used
new stock rocker shaft and rocker set used
stock pushrod set used
turbo crank
turbo crank
turbo crank
hypertetic pistons 60 over w new rings
speed pro forged pistons 30 over used
8445 stock set of heads,used bare
8445 ported set of heads with oversized ss valves and roller cam kit springs hd shafts and stock rockers with roller cam setup reusuable full throttle 210/215 with double roller
race built block 10psi oil pressure on first run 40 over forged pistons stock rods and crank roller cam billet main caps.all arp, main studs headbolts and rod bolts
60 over fresh stock block with new stock cam and bearings
parts/any photo
35 EGR blockoff plate which one?? Any photo?
200 Fuel lines at front cover SS, used photo
email sent
Dang...Hope those parts are all brand new....and all chrome plated...:p:D...but seriously $75 for a IAC sensor..lmao
few questions,
1. new or used
2. if used are they in good shape?
3. are they for turbo application?
if there in good shape and for turbo app., i'm interested if price is reasonable.
thanks
Dave
Not quite sure if that's his prices or ??
He wants $130 for an accufab regulator you can buy all over for $109 ?
He wants $189 for TA's valve covers that you can buy new from them for $160. ?
I think all of the prices listed are cost of what the parts were when new. He is taking offers.
Bryan
Is it me or are a lot of his prices more then what out venders sell these parts for new. like the fuel pressure regulator $100 from FT and the EGR block off I just got an egr block of from g-body and it was less then $20, a new scan master is $250 . He rilly needs to check out pricing with the venders here and rethink his prices and repost this.
are you ppl serious??? If you bothered to take the time to read you would see thats just the new price to give you an idea to make an offer! So lets not just destroy a guys chance ignorantly to sell some good items!!
once again this is why i hate forums yes diff vendors have diff prices this is what i paid for them at the time at least im giving the prices so its convienant for the buyers to make an offer! Why do you ppl like to kick **** in each others faces???
email me serious offers with reasonable shipping included to mattbrisbon@gmail.com I have paypal check and money orders.
If the offer is reasonable and youve supplied your phone # and shipping address I will call you and arrange payment and ship it out.
price item
if
new
50 belt used
150 starter new
170 MAF used
34 used water pump
64 TPS like new
75 IAC like new
80 test pipe used
unpriced
turbo crank
turbo crank
turbo crank
hypertetic pistons .040 over w new rings ******changed
speed pro forged pistons .030 over used ******changed
speed pro .040 forged pistons used ******changed
changed the piston info
also have
stock good d5 convertor
stock downpipe with cat
stock turbo with actuator
stock intercooler
stock upper a-arms
stock upper plenum and throttle body
stock sway bar
Are the new stock style rocker shafts solid core? If they are please PM me a price, Thanks:smile:
