I don't know if I'm out of line here but I hear there's some people here with lots of Gen 7 experience. I'm helping a friend with an LS1/Gen 7 setup. Does anyone know if the crank position sensor in the LS1 will work with a Gen 7? Some parts of Accel's web site seems to indicate it will work, but some of their documentation says the LS1 has a 24 tooth ring and the Gen 7 will only work with a 4 tooth ring.
Also, lets say I was just concerned with maximum horsepower and just a little driveability, what sensors would I need? I'm uncertian if I need the Manifold Surface Temp sensor, the Inlet Air Temp sensor, the MAF is gone already. I know I need the TPS, the MAP, the cam position sensor and crank sensor. It's got a wideband O2 sensor. Am I on the right track?
About the knock sensor- do I need anything to interface the stock LS1 knock sensor to the Gen 7? We may go to a solid lifter cam, will the knock sensor work with this?
I've done a few EFI conversions, but this is my first time with a Gen 7. Getting information on the capabilities and requirements of the Gen 7 isn't easy. I want to get everything I can out of the thing.
Please help me out.
Here's a pic of my 95 Roadmaster LT1 to 89 IROC conversion, did it all myself and it started and went into closed loop on the first try. I'm really good at soldering wires
Here's the HUGE TURBO part, my home made afterburning jet go-kart-
I built this for about $200, the turbine was made from a huge turbocharger off an M-60 army tank. This is the slowest cheapest POS I ever took to the strip, it's also the most fun. It does 70mph in just under 20 seconds. I was on Junkyard Wars with a similar project.
Now I'm just trying to set up this Gen 7 and I don't want you all to think I'm a total noob. If anyone needs help with a jet engine or any laser/waterjet cut parts let me know. We have some awesome laser and waterjets where I work. Thanks for your time.
Chris
Please help me out.
Chris
