- May 28, 2001
Did a search and an OLD thread I started is now back!
This time it's on a 71 Bronco. A DIY deal by someone yrs ago, using a HB without the safety accumulator.
This involves a brake failure via the rear hose being torn off. Luckily, the prop valve allowed for some ft brake.
The system was allowed to get dirty/rusty and required a new m/c and prop valve.
All's back together and the problem is:
Engine started, HB is charged and brakes "kinda work". Need bleeding.
With engine off, as we attempt to bleed, the p/s fluid in the HB bleeds back into the p/s reservoir and there's no pressure transmitted to the m/c.
My contention is the HB is fried and leaking internally.
Anyone help with ideas will be appreciated!
