Hydro Boost Promblem ?
87GNPARTS
When I First Start The Car And Apply The Brakes,red Brake Lite Comes On After Pumping The Padel Once Or Twice The Lite Does Not Come On Untill The Next Time I Restart The Car (87 Gn).is It The Hydro Booster If So What Parts Would I Need To Covert The Sys.
87gnparts
87gn does not have a hydroboost system, it has a powermaster unit. that noise you are hearing is probably from the accumulator ball
Powermaster Problem
Thank you for the info. I will check out the accumulator ball.
If this is bad would this cause the brake warning lite to come one when I first start the car,will not flash untill then next time I start the car.
THANKS AGAIN FOR THE INFO
87GNPARTS
