Hydroboost problems
First thing I did was make sure the parking brake was off.
I have a feeling the sensor at the proportioning valve is turning the light on because of all the air in the system.
I think I am going to purchase one of those reverse fluid flush kits. Would be useful on more than just the GN, and it's easier than finding the correct master cylinder adapter to use the Motive products.
I just used to pieces of metal brake line with the correct ends for to screw into the master cylinder. Then bent them to point up, just 4-5 inces total length. Then a couple pieces of clear aquarium tubing that happened to be sitting on the shelf. Then bench bled the master on the car. Then bled out the rest of the system like normal. Worked perfect. You are going to love these in the end. It will all be worth it.
