hydroboost question
CHANCE
No longer a Buick guy!!!!!!!!!!!!!
How do I route the lines on a hydroboost set up if I don't have a power steering box? What I mean is I want a hydroboost set up but I don't want to get rid of my manual steering, so how would I run the lines?
You must have a power steering pump and reservoir...... I would assume you don't since you went manual steering?
I haven't personally tried it but I would say pressure in left port, plug right port, and lower port would be return back to the pump/reservoir.
Hydratech Braking Systems - Technical Information
I would think by eliminating the steering circuit seen below it might work. However, I would question if you will have too much flow through the hydroboost unit.
