Mike T
- May 3, 2013
My book sounds like a smart ass and that wasn't what I meant for it to sound like
SignUp Now!I have always found your advise to be solid and consider you one of my top 5 sources of info on here.
The way my question was worded it completely eliminated spool up, charge temp and drive pressures in order to compare apples to oranges for lack of a better way to put it. Eliminating those factors 20 pounds is 20 pounds in my book so how would the motor perform any better.
the larger turbo will be quicker and faster to the finish line .. Period
This is applying what you outlined as the points in your scenario
is 20 Psi in a bike tire equal to 20 psi in a tractor tire ?
Obviously volume and PSI are two different measurements was just trying to keep it simple.
you said 20 psi across the board from start to finish ...60 vs 70 .. volume plays into it
Honestly I was considering a 6766 since a lot of guys say they are tried and true performers. After running the car at the track I started to question how much difference could there really be between the two if leaving at similar boost pressure. Maybe a little quicker spool for 100 feet?
Before we carry on.....Thank you guys for engaging in this unusual discussion. It's been boring as heck around here![]()
in your scenario .. 60 vs 70 both @ 20 psi = huge
I'm not good with formulas but I believe that two compressors blowing into the atmosphere would have different volumes but blowing through a restriction at the same psi would yield the same volume.
I can give you an example ... H3 compressor @ 17 psi and a 68-1 @ 17 psi was 17 mph difference
i like a good smart assMy book sounds like a smart ass and that wasn't what I meant for it to sound like![]()
thanks,but i get where your coming from mow just reread that question again.20psi is 20psi you are correct in your fantasy questionI have always found your advise to be solid and consider you one of my top 5 sources of info on here.
i have seen that multiple times.all the combos i have seen only run faster with lower boost if they have better air pumps.if not they only go faster if they increase the boost number.two compressors blowing into the atmosphere would have different volumes but blowing through a restriction at the same psi would yield the same volume.
thanks,but i get where your coming from mow just reread that question again.20psi is 20psi you are correct in your fantasy question![]()
its also the way it was posed,your question mimics a nitrous car which has a much higher power average throughout a run.For the most part it is unrealistic. For a long time now I've been reading post that aren't technically correct if we look deep into the basics.
