Update # 9
With just a few days left before I pack up and head to the Nats, I thought I would give an update as to what I've been up to with Legend. Bare with me as this one might get long. Here we go.
First I will list everything that I was able to get done.
- Order and install a custom car cover from Coverking. Holy cow this thing fits perfectly. No more Cover Craft junk for me.
- Installed Kirban's underhood brace kit, Front frame braces and just this past Friday, the rear seat brace kit.
- Made a custom I/O panel housing using a fried Netgear USB to Ethernet adapter cables' housing. Not bad for something that was just going to be thrown in the dumpster. Re-purposing 101.
- Installed a pressure transducer to monitor alky pressure and used a pre-made 10ft long wiring harness, cut to length.
- Installed an AEM 3.5 BAR MAP sensor and another 10ft long wiring harness, cut to length. Plumbed the vacuum line directly from an un-used port on the vacuum block and mounted it to one of the factory blower motor screws with a cushioned clamp. My thought process was to keep all of the vital vacuum lines from the intake, in a centrally located spot.
- Make a harness for all wires that run into the new I/O housing.
- Install I/O housing close to the factory MAP sensor area.
- Install a 15ft long 8 pin mini DIN cable from the new I/O housing, routed inside the cabin to the Powerlogger/ECM.
- Ordered a 90* male to female USB adapter and a short male to male USB cable. This allows me to put the laptop in the drivers seat with the cable connected to the USB port in the ashtray switch panel.
- Drain alky tank completely.
- Removed and replaced the 3 year old Alky pump with a new one from Julio. Put more split loom tubing on the wiring harness and all lines for protection against rubbing / chaffing.
- Flushed and replaced the brake fluid, following Richard Clark's step by step procedures. It was nasty and probably hasn't been done in a very long time.
- Took care of the broken power antenna and plugged the hole.
- Swapped serpentine belt to a Continental Elite Poly-V 38" belt. No more noise and the tensioner is happy.
- Installed a factory alternator tree brace that was missing. Shout out to FatNat for hooking me up.
- Change the oil with VR-1 10w-30, ZDDPlus and clean the billet filter thoroughly. I now know what my "true" hot idle oil pressure really is.
- Have new Moroso DS-2 front tires mounted and balanced on the skinnies.
- Finish polishing up the Aluma-Stars and install them with a set of new McGard open end lug nuts.
- Remove both rear seat sound deadening pads and the rear seat belts for weight saving.
- Trim some of the t-bolt clamps with a Dremel tool.
- Remove all un-necessary items from trunk and inside of car.
- Vacuum trunk and under the back seats before putting the rear seats back in. (Rear seat brace kit install)
- Install new TR Custom Parts front license plate.
- Install "Dark Gray JEDI mind trick propaganda" on the windows.
- Thoroughly wash and wax the car.
- Touch up paint certain spots.
Now for the bad.
These items on my to do list, are things I will need to do at BG. I honestly ran out of time.
- Swap plugs with a fresh set of Autolite #23's. (normal track to-do list stuff)
- Install drive shaft safety loop.
- Install trans temp gauge and manifold, run wiring into the car to the gauge.
- Install Derale trans cooler with fan, Hook the fan up with a Racetronix universal fan wiring harness.
- If needed, drop the tank and replace the Walbro 255lph pump, with a new Racetronix 340lph fuel pump. Probably won't be needed, but just in case.
- Install AEM UEGO gauge and WB O2 sensor.
- If needed, replace both lower intercooler hoses and their t-bolt clamps.
- R&R stock starter with a light weight one from DB Electric. Big weight savings item that is out of sight, out of mind to most.
- If needed, install line lock, rear x4 long brake shoes and larger 7/8" bore rear wheel cylinders. Brakes hold good now, so another just in case.
As you can see, I've made good progress. Mainly this past month as the weather finally started easing up a bit.
And with that, I will bring this update to a close. I can't wait to get to BG and see everyone. It is really hard to put into words just how good it feels to be back in the Buick game again with another car. I will be testing and tuning with mine, as I don't forsee trying to race in any class. I will also be helping Dave with his car. Stop by and see us under the big circus tent.
Thanks for following along with my antics and I hope everyone that's going to BG has a safe trip.
And lastly, some recent pics.
Old pump
Repurposed
Let the fab work commence.
See everyone at Bowling Green.
-Patrick-
