When i get on my car and it shifts from 1st to 2nd its like a 2second lag then it changes out smoothly with the rest of the gears...do u think its starting to slip...it used to hit 2nd hard!
You Need To Check If There Is A Pressure Drop On The 1/2 Shift With A Gage.if It Doesnt Drop The Accumulator Spring Should Be Checked As It Is Probably Broken
a leak in the circuit that supplies oil to the band.this could be the valve body gaskets,the servo seals,the accumulator housing ,the accumulator piston etc.
Thank's for the help chris, i am taking my tranny to the shop tuesday i hope he can do it right this time, if not, I will send it to you chris thank's again.
