well im gonna drain my radaitor tommrow when i wake up..it was recored like a year or 2 ago..and im sure the fluid needs to be drained..the car has been running hot also..not boiling out of the overflow tank hot..but hot..lol..like 200-215 degrees sometimes with the air on high..so im gonna drain out the radaitor and i wanted to know if i could just fill it back up with pure water because i heard antifreeze can be bad?..or what do you guys suggest?..i plan on upgrading to the dual fan setup in the future.. whats the best way that you guys recommend to really flush the system good also?
and what are some tests you can do to make sure the coolant system is working properly?..to break it down to either the rad, or the fan, or the water pump or what have you
