blackgn231
Money pit
- Mar 28, 2007
Was replacing the filter and fliud thought it would be a good idea to install a drain plug. Well marked it off but did not look at the filter, well drilled thye hole and now the bolt in the pan that holds it is hitting the corner of the filter.I can either try to have it welded up and drill new hole, weld or braze the plug in and do away with the inside nut, or buy a used or new pan so what do you guys thing help.
