Changing Monte SS over to manual brakes. I was told i need a brake pedal and the pushrod and plate from a mid 80's style s-10 with manual brakes. Thanks,Frank
No, the S-10 pedal is too long.
The N/A G-Body, has a hole in the right location, for mounting the pushrod too.
The GM Manuals have the push rod as being part of the Master Cylinder.
I'm putting together a pictorial for doing all this, if you just stay tuned to the library, I should have an article up in a fews days, 2 weeks at the outside.
Yeah i was told i need just a pin out of the s-10 pedal to weld in the hole of my g-body pedal. then the manual brake s-10 rod that i think will need a slight modification????????? Frank
