I need help waking up my stock hhot air turbo motor
kad5118
hello every one
am new to turbo buick.i dont quite have a buick i have a stock 1980 monte carlo that is turbo.its the hot air turbo setup.right now i am trying to wake up the engine performance.i currently have a hholley 950 commander efi setup,that i plan on using to replace the carb, and a mallory ignition setup to add to enhance the spark. and a stock th35o trans to work with my stock current turbo engine.i do plan on have the short block rebuild.what are my options i am aiming a to receieve over 22mpg and close to 350hp at the rear wheel setup.what are my options.i have a fair budget to play with what are my options,any advise will help.
You will get more responses if you post in the Before Black section,just below the hotair section.:)
Bore the engine over, 84-85 heads, .480-.470 cam, T4 turbo, adjustable wastegate, 500 cfm carb, shift kit, and 2500 stall converter. Do not forget the 84-85 headers.
