ChrisCairns
Senior Member
- May 24, 2001
I went racing today and on the first pass the cracked rocker shaft broke. I knew it had a small crack right where the bolt passes into the pedestal but since the shaft retaining cap is right where the crack is I thought that would hold the shaft even if it broke. And it did. Except it took the threads off the bolt so the bolt backed out and I assume then broke the shaft in half.
Every hole in the pedestal is thread serted so I assume the threads on the bolt were the weak point.
So I REALLY REALLY REALLY need a shaft now. Anyone have one??? Pretty please?
