i am still trying to find out what is wrong with my car first it was popping through the air cleaner and surging when the temp out side dropped it stopped that i put a scan tool on it this is what it said tell me what this means . loop status closed.
02 sensor (MV)635
prom id 394
egr duty 0
rpm975
esc counter 0
o2 rich it stayed like this for a long time then went to lean for a split second
mat 92
spark advance 37
tps sensor.29-31. it kept going between these numbers
blm 137
coolant temp 165 it never went over this and the fan stays on high doesnt go off.
iac position
integrator 133
the only thing i did tonight was set the tps to .43 the idle smoothed out it was running rough when it was at .29 i took the computer out it has some type of home made chip in it not factory
i need to find out what these specs mean please help
02 sensor (MV)635
prom id 394
egr duty 0
rpm975
esc counter 0
mat 92
spark advance 37
blm 137
iac position
integrator 133
