Does the IAC Reset Procedure on gnttype.org refer to engines that are stock, modified or both?
The problem I have is that at park/idle, closed loop, engine at normal oper temp, the IAC count is at 00. The TPS is at .42 / 4.8 WOT. If I put it in gear, the IAC will go to about 05 then drop to 00. Is this normal for my mods (see sig)? The RPM at park/idle is about 950-1025, in gear about 850. Also, once the car is fully warmed up, the RPM s will fluctuate from about 1000-1150 until I put it in gear and stay steady around 850. Put it back in park and its back to fluctuating after about 30 seconds.
I tried to reset the IAC per gnttype.org but as I was turning the screw CCW to raise the count, it got up to about 03, rpms dropped and engine died. Of course the TPS changed also. So I just put it back to where it was. I don't know how else to get the desired 20-25 counts if the car won't stay running past 03 counts.
Also, when the car is started first thing in the morning, it will run for about 2 seconds and then die. On the second try it starts right up.
All sensors are new and about 5 months old. KDK Performance in Orlando did all the sensors and adjustments and has been running fine until about a week ago. Checked and replaced all vacuum hoses. All other Scanmaster readings are normal. Please help.
