Here are some pics of the JS Manufacturing IAC relocator. Its was intended for use with their kit due to the limited amount of space between the bottom of the 87 TB and the thermostat housing on the 85 intake.
I have no need for mine now 'cause I cut the top off my therm housing and welded a plate on it. Works great so far - no leaks. I had to cut the crossover tube off as well - welded that shut. Added a fitting on a drilled and tapped port on the top of the intake and attached the hose that went to the x-over tube there.
I included a pic of the IAC monted backwards on the relocator - depends on where you were mounting it - could come in handy. The plate you see was also used to block off the bottom of the 87 TB when the IAC is removed.
