If I am tuned for meth/water, can I run straight meth + 50shot?
KyleH
I am new and tryin to search around the forum, but I couldnt find the answer to this.
If I wanted to run a 50 shot at the track, could I run straight meth to richen up the mixture a bit if I am tuned to run windshield washer fluid?
This is with an unintercooled novi 1K w/stock pulley on a 4.6 DOHC lincoln Mark VIII, full weight 3.07 gearing stock motor/trans.
Your wanting to run a questionable mix and nitrous on the cheaps.. Good Luck.
Your answer is yes, but not for very long :eek:
no offense
but that would be like saying can I put a twin turbo stage II in my car & run 40 psi on a stock ecm & 87 octane. You got to look at it this way. If your running one power adder & then add another why in the world would you risk it on a questionable tune? Run it on straight methanol with the 50 shot then tune it for that :eek:
You should re-visit your tuneup for even the slightest change in your setup.
I agree. The old addage "you get what you pay for" really is the truth when it comes to this stuff. If you do a cheap job, you get cheap and sometimes detrimental results. Don't focus on the turn; focus on the road ahead.
B
