Ignition Module/Coil Packs
Robes87GN
Bench Racing Hater
Where can I find these? My car is doing the sputter, which I previously thought was the trans, but I dont think thats it anymore. After reading some posts about this, I figured the coil packs and ignition module were the root of the problems. TIA.
Robes
There is a user on the board, RedRegalT, who sells used and tested coil pack/module combos. I've had good luck with the one that I bought from him and they're a good deal.
Check the top spark plug wire terminals on your coil pack for corrosion....
seems to always be my problem...
i got the type 2 from gm. 2003 monte carlo, caspers adapter for the hot air gn.
andy
Thanks for the help! Any performance upgrade ones? I want to get as much out of my car as I can this year before turbo/injectors/torque converter/intercooler/cam upgrade next winter.
