pmoore4321
- Jan 10, 2010
You could cap the lead. I just left mine cut. It will be insulated when you re-wrap the bundle with tape.
SignUp Now!I don't think it is real critical in this application. A 5-amp would probably work. I don't know how much amperage the ignition module pulls.
Thanks, looking at the fuse panel and the CCCI is 10amp and the ECM is 10amp so I'll be using 10amp.
I don't think this is compatible with Bob Bailey's new two-step, if anyone is considering doing both.
If a voltage booster is being used on the car and the entire electrical system is affected then the primary ignition coil is also seeing more voltage.How much of an increase in voltage occurs at the primary coil occurs when using just the hotwire? Now with both voltage booster and hotwire the voltage increases further.Are the secondary windings coating adversley affected by a continuous voltage increase (ref V=IR)?...premature coil output deterioration??...any thoughts?
Hi,
Are you sure you have the coil boot's fully seated ? They look like the terminal is not on the post. Did you hear and feel a click ?
