meanchicken
gallo vicioso
- Oct 6, 2007
I can’t imagine anyone willing to take beer money from a guy serving in Afghanistan??
We should be sending you beer money!!!
X5000 on that one.
SignUp Now!I can’t imagine anyone willing to take beer money from a guy serving in Afghanistan??
^ Copy That, Bossman!
These are my t-type of people!:biggrin:
The first step would be fitting the engine with a "mid-plate" restraint to control block twist before you actually twist it out of centerline.
Holding an engines position by front mounts or tie-down strap is not in your best interest, although it is much easier and does accomplish anti-movement, you are asking the block to hold back the rotational forces fed back through driveshaft/transmission during acceleration, This is number one reason for cracked #3 main cap. I am a proponent for girdles but even they can't resist these forces.
Yes, steel caps conform to movement that castings won't(steel can distort, castings do not) but you would still experience bad wear on main journals because crank centerline(block) moves if held by the front.
This modification (mid-plate) will solve lower end failures(except oil pressure related issuse's), but head sealing will still be problematic if tuning is not right, pushing timing advance with leaner fuel mixtures will create higher peak numbers, but these peaks are what you should avoid.
If you keep these forces in mind, creating horsepower gets easier when you dont have to replace short blocks frequently, others here have much more experience with latest power combinations than I am, I haven't touched a 3.8 since the late nineties, 3800's rule in my book.
Good luck.
Kevin.
