SignUp Now!I think he's just making a point that once that line popped off you no longer have control of the boost and could easily overboost. The reason I ask if its electronic is because your gauge could be out of calibration or too slow to catch the spike. With those injectors you'd lean out real quick.Serious you think i ran the turbo with no vacuum line on it. Read my post it came off along with pvc valve blow out of its hole at the same time.
No, a blocked pvc would pressurize the crankcase. By chance, did you happen to notice if the vac. line that blew off was the one removed and reinstalled by the mechanic? It may have been possible that he didn't reinstall it completely and it blew off under pressure. Causing an overpressure condition, resulting in the mishap, as previously stated?Pvc you say should be blocked off?
