Info for modified ECM's
TurboBob
Resident mad scientist
Staff member
As many know, I modify the ECM's for peak and hold drivers. I use the correct 2.5 amp drivers for the 2 ohm injectors (55's, 72's, 75's, etc.)
Over the years, I have seen many kinds of "reman", "rebuilt", whatever ECM's from many sources. The quality of these units has been poor.
I believe its getting worse as time goes on, as these units are so old that they are lowest priority among the ECM repair outfits.
If you want to get an ECM modified, please do the following:
Get a good, non-remanned ECM. The one from your car is best, since you know its history. You can also get one from various "recyclers" that post here on the board. Get one with no water damage tio the connector, "pretty ones" actually seem to be the best ones.
Make sure it runs, drive it around a little.
THEN send it.....
Bob
Questions......?
How can you tell if an ECM has been remanufactured? :confused:
Thanks!
From the outside: odd stickers of different sorts, case repaint, etc.
Bob
I have seen some problems with the reman ECM's from the parts stores like Checkers...AutoZone...etc but what about the remans from GM...I bought a GM reman a few years ago and have used it a couple of times...seems to work OK...just wondering what you've seen with those ECM's...also once an ECM has been modded for say 72lb injectors does it need any additional mods to work with 83lb injectors...
no additional mods needed going from 72's to 83's....
I have seen a few official Delco remans, they were ok.
Bob
MAP sensor input
Do you do this too Bob?................................................thanks Bob
Super6 said:
Map sensor mod
I do the mods for the ME-R. All this work is scheduled thru Steve Y. When you order your ME-R, you set up to get the MAP mod done with him.
Bob
thanks
I bought the ME-R used and Steve has updated my chip to the newer version so i guess it should be good to go...........................................Bob
Bob Modded My Ecm And I Love It ,83#siemans , But I Used A Brand New Computer I Bought From Poston In Bowling Green!
Bob is the man! Thanks again for taking care of that "freak" bad injector driver so quick. Car has been running awesome ever since!
Sean
