SignUp Now!just pop the cap on and put 2 or 3 dabs of silicone on the back side and call it a day....
Yes, to use the rear GTA's on the front of your G Body you will need a spacer (unless you have upgraded your front brakes to the LS1 setup). Some claim as little as 1/4", other as much as 5/8" with everyone else in between. You should install longer wheel studs also.
Here's what I did: Called Classic Industries and ordered 4 of the GTA wheels with the zero offset. $699.99 plus shipping to my door. They have them in stock now. I ordered my lug nuts with the black covers from Kirban's and also ordered the GTA/GNX centers from Kirbans. Last but not least I ordered metal decals from buickgn.com. When it was all said and done I have less than a grand in them minus the tires. I went with 245's up front and 255's in the rear and I have absolutely no rubbing. Hope this helps.
How about some pictures to compliment this post?
The non-dimpled 2 piece are the best kind. They can EASILY be cut out and rewelded for a proper GNX offset. :biggrin:
These are the ones I've posted pictures of above. If you buy 4 you get them for $699.99 plus shipping.
Covered in post # 48 above.You got those wheels from Classicindustries did the come with the Center caps or did you Purchase them separte what back sapancing did you get did you get 4 fronts with the zero offset
Dennis Kirban does not have an identical wheel. Dennis's new style is virtually identical to his old style, as the webbing in the center runs out more to the outside of the rim as compared to those pictured.Just an FYI on the latest Inner Circle from Dennis Kirban it sounds like he has an identical wheel with the proper zero offset, caps, lugs with black plastic covers and new valve stems for $999.99. Sure would have saved me a lot of trouble had I known about this when I ordered mine but I think he was out of his old style at that time. From his discription of the wheels they sound like they are identical to the ones I bought from Classic. The only other thing you would have to buy would be some center inserts which I highly recommend Mark Hueffman's products at TR Custom Parts 84-87 Turbo Regals, Olds G-Body Cars, S-10 Blazers/Pickups.
