0-60n4
- Nov 17, 2003
I have not confirmed what chip is in this car. The paperwork appeared to be TT 60lb. It came with a boost gauge, fuel pressure gauge and an old ATR L.E.D. a/f ratio display. The a/f ratio display goes full rich on WOT so I figured it was safe. 17 psi boost. FP rises 1:1 with 40 psi at idle with the hose connected. The car pulled OK at first but then leveled off pretty quickly (kinda flat really). I figured it might be running too rich.
I got a Scan Master this weekend and hooked it up. Wow, lot's of KR at WOT. Like 15 - 19 degrees. O2 volts was aronnd 830. Running 93 octane pump gas. So I wanted to confirm it was really knock and not false knock so today I removed the 93 octane and put in 8 gallons of 110 octane. BAM! pulls hard the whole way with 0.7 degrees of KR althoug I could see a momentary blip durning 1 - 2 WOT shifts. Feels much better. I have an Inovate Wide Band O2 sensor on order.
So I'm guess the chip must be a race chip with lots of timing advance. Make sense?
I don't drive the car much so I could live with a full-time race gas car.
Questions: It appears to have a manual boost controller under the dash. What would be a safe boost level on 110 race gas?
What O2 volts should I shoot for?
What's good but safe A/F ratio?
What is acceptible KR?
Next I plant to experiment with Octane to see wha the minimum is I can run with out getting knock. 110 may be more that required.
What are my best options if I want to run 93 pump gas?
1. turn boost down.
2. don't step on the gas pedal.
3. change chips
4. Alchy
5. other?
Thanks,
Jim
1. turn boost down.
3. change chips
4. Alchy
5. other?
Thanks,
Jim
