Injector Size
2
2slow
Guest
just got a regal it has 40lb injectors and a stock turbo[had a big turbo but was sold before I got it] will these injectors work with this turbo? what size are stock...thanks John
I believe stock are around 30lb injectors. I think they may be a little smaller like 29.5lb or 28lb. Those 40's should work fine with the stock turbo as long as you have a chip burned for them from Red Armstrong or any of the other vendors.
injectors
got 3 chips jay carter street,red 108,and red race with lockup and 21 + psi are chips made for turbo size and injector size or just injector? The motor pours black smoke when kicked.....
