Oct 4, 2005 #1 B BEATBY6 Member Joined May 28, 2001 Messages 628 http://www.innovatemotorLM-1: Digital Air/Fuel Ratio Meter Tuning an engine for maximum power previously required long trial-and-error sessions on a dynamometer. With the LM-1, precise AFR measurement allows the user to correctly adjust many variables- including carburetor jetting, fuel injection, turbo fuel curves, etc.- without long and expensive dyno sessions. The meter’s digital signal processing technology provides data on exactly how rich or lean an engine is running at any load. The LM-1’s self-calibrating circuitry also compensates for changes in temperature, altitude, and sensor condition. The instrument can sample and store 6 channels of data- air-fuel-ratio and up to 5 other sensor data channels- internally in operation for later analysis on a personal computer. At a sampling rate of 12 samples/second the instrument can store up to 44 minutes worth of data in non-volatile memory. The data can be downloaded to a personal computer using a standard serial port and viewed/analyzed by the included software or any standard spreadsheet program: The LM-1 is available in various kit configurations: 1) The Basic Kit ($349) includes a the Meter, a Bosch wide-band oxygen sensor and cable, cigarette-lighter power adapter, serial cable for PC connection, 9V battery, exhaust bung and plug, CD and manual. sports.com/products/lm1.php It is brand new never used.I will sell for 299 shipped your door.Thanks,Scott
