Since I always were the outside edge blocks away on the front tires first, -1 degree of camber actually reduces tire wear for me vs. 0 degrees. It depends a lot on the type of driving you do. If most of your tire wear comes from high mileage, zero to -1/2 might be better. If most of your tire wear comes from highway off ramps -1 to -2 degrees might be better. With todays assymetrical tread designs, negative camber will help save the outer tread blocks, because once they are gone, the tires are junk.
Did your arms come with "Offset" shafts? If so, instead of more or less shims, the shafts can be rotated 180 degrees to move the upper balljoint in or out and then shim from there. I wouldn't think you would need much more than an inch of shims and even less with offset shafts.
