Donald McMullin
 - May 25, 2001
GNVAIR:  Do you have the measurement of the of the steering arm height on the B-spindle from the bottom ball joint??  I have spare stock spindles I would like to compare with.  I do not have any B-spindles, that is why I am asking.
Thanks for your response. Your loose rear could be attributed to:
(1) not having body bushing
(2) loose trailing arm bushings allowing sideways movement during cornering.
(3) Loose bushings and lower arm angle allowing rear toe-out during corners. If you have the rear lowered this should improve instant center for better loading of rear tires, and shoud reduce rear toe-out.
Deep Enough
Donald McMullin
Deep Enough
Donald McMullin
