I have to install my S10 ZQ8 coils with no weight on the front end, so I need to compress them I guess. I have heard that when using a spring compressor though, the long bolt tends to hit the top of the frame before the spring is in.
how do you do it, never used a spring compressor? fit the compressor in the spring, slide the end with the hex head through the a-arm shock hole and use an impact gun?
do the balljoints simply pop themselves through the spindle hole when I tighten the castle nut, or is a BFH needed?
I guess I take the spring compressor apart to free it from the now assembled suspension?
I've also heard that you can compress the spring outside of the suspenson and tie it with 3-4 coat hangers, install, then cut the wire, but.... that sounds dangerous
so basically, how do I do this without being clobbered? everything I've read is assuming the engine and body weight will hold the frame down.
is there a certain way to "clock" the springs, or does it matter?
