I pm'd Nick Micale and he confirmed that I installed it correctly dot to dot. Anyway it was nice to see that there weren't any broken teeth on the original cam gear but the tensioner spring sure was weak and quite a bit of slack in the chain. The TA timing set fit very nicely.
I took care of that today. I could feel the point in the center of where the cam button had been wearing. I won't have time to put it back together until next weekend. Still need to pull the oil pan off and clean it up.
Got the roller cam button. I also cleaned up the inside of the front cover where the original crank seal had been staked. Checked for slack in the oil pump driveshaft and it checks good. I will prime it per the instructions on gnttype.
