Flush out your IC. I used some gas & then flushed with water. After that I used some rubbing alcohol to remove the water. Kirbans has a kit that replaces the rubber hose that runs from the passenger side valve cover to your turbine inlet. That is most likely where the oil came from. The kit includes a K&N type of breather for the valve cover & a block off cap for the turbo.
Good luck
~JM~
