87hottness
- Feb 17, 2011
Has anyone ever used the co2 intercooler sprayer on the sock intercooler just saw a kit and was wondering if it actuaalt helped at all thanks for the input
SignUp Now!Nice, now we can calculate the correct sized CO2 bottle for what size feet we have! Thanks for the info.
A CO2 spray kit when using a stock intercooler would be a waste of time and $$$ on a GN especially using pump gas, BUT in a race situation it is well worth the $$$ if the rules allow it.
I personally know of one turbo Buick powered race car that had awesome results cooling the front mount IC. It dropped the inlet air temp almost 50 deg. when spraying down the track vs. no spray.
There are a few other turbo cars using spray with similar results.![]()
I guess the question is will the track let you spray CO2 down the the track? Being in AZ i have though about using something like this. I am quite sure the temp of high pressure Co2 discharged is much colder than ice water. Ive seen that stuff freeze 1/4 " lines in seconds.
Gotcha. I'm probably going to add this to the list of things to do eventually and give it a shot with c02 once i get a good baseline with the car.
