My interior lights started staying on all the time but they are dim. They do turn on bright with the doors open or the dimmer switch turned on. The ground circuit seems to have a short but with some resistance. I've checked the more typical failure points including the door jamb switches and the dimmer switch. I've disconnected each one with no change in status. By disconnecting the connector, C209, I confirmed that the circuit for the footwell lights is not the culprit. Also, I checked the resistance of the dome light circuit at the C453 connector. The short seems to be between the door jamb switches and the connector C453. I moved the wires around near the door jamb switches with no changes in the light intensity. So, the failed point is not near the switches. Would anyone have an idea as to where the white grounding wire may become shorted?
![SchematicInteriorLights-8a-114c.jpg SchematicInteriorLights-8a-114c.jpg](https://turbobuick-data.community.forum/attachments/119/119139-8fda47310c2f2c7b7410ef87ded6801d.jpg?hash=j9pHMQwvLH)
