internal waste gate actuator help
vader87
Protected Freedom for 27 years! Thank a Veteran!
Is there anyone who can setup my actuator with a bracket so that it will mount on my pt6466 CEA gen2 turbo? I have s new hd actuator. I am running a ta 3.5 internal gated pipe as well. Thanks for your time and help!!!
it will need a bracket welded to it depending on which compressor cover you have. If you get it clocked the way you want it and send the turbo to us we can make it work for you
Thanks Mike for the response! I think I have it worked out but if not I will contact you!
